520/ 530 JD REPAIR MANUAL FOR OVERHAUL
Tyler-MO
09-01-2003 14:31:51
I have a repair manual from JD for my 720, but when I began to search for one to match my 520 I was unable to get help from JD. Did Deere ever make a service manual for those tractors or should I go by the general ideas in my 720 book. I especially need assistance for the tolerances and clearances for bearings and such in the transmission. Where can I get the specs and to know if there are any tricks in going through my tranny? Thanks for any ideas Tyler
JDVan
09-01-2003 21:45:20
 Re: 520/ 530 JD REPAIR MANUAL FOR OVERHAUL in reply to Tyler-MO, 09-01-2003 14:31:51
Your best bet to get these tolerences will be from JD Service Bulletins or from the I & T manual for the 520.
Duane Larson
09-01-2003 15:27:16
Tyler-MO
JD did not make a service manual for any of the 20 or 30 series, except for the 720 for which they provided separate manuals for the gas and diesel versions. The 720 manual is as close as you can get with JD provided info. Torque specs, etc. are given in the JD Field Service Bulletins.
ellis
09-01-2003 16:21:09
 Re: Re: 520/ 530 JD REPAIR MANUAL FOR OVERHAUL in reply to Duane Larson, 09-01-2003 15:27:16
I have a manual from Tractor Supply Co. that covers 520, 620, 720, 530, 630, & 730. They are published by I & T and appear to be near copies of the JD manuals.
In my manual and also in the JD shop manual there is a discrepancy in that they both show the 730 transmission gears to be the same as a 520 with reference to 1st & 3rd, 2nd & 5th and 4th & 6th. A 730 in reality is 1st & 4th, 3rd & 6th and 2nd & 5th.
