49 A styled shutters
tim in Ohio
09-01-2003 09:57:28
I have been having a problem with fouling plugs (Chamion D 14 Y). I see alot of guys like the autolite 388. I also noted that since I am not "working" the tractor, and getting it up to a good maintained operating temp. that could be paqrt of the problem. If so why has someone removed the shutters and where can I find a set, so that I can cotrol the operating temp?????
Thanks..... ...Tim
Lee
09-02-2003 03:50:35
 Re: 49 A styled shutters in reply to tim in Ohio, 09-01-2003 09:57:28
Shutters are typically removed to aid cooling or were simply not put back on during a teardown for what ever reason. Junkyards or tractor meets might have a set but most wound up behind the barn.
It's not so much the high temp that's needed to keep these old girls from fouling, but a good work out to renew the 'glaze' on the cylinder walls which then keeps the oil below the oil ring. Shutters alone won't help much in that area, she just needs to work like she was made to do. Renewed glaze might last longer with shutters, but I have no idea how long - too much depends on condition of your tractor like years since last overhaul and if you are running a rich mixture. Starting with full choke might flush oil off cylinder walls allowing rings to cut into glaze more than is normal also. Only way then to get new glaze is WORK.
jdman(MO)
09-01-2003 19:42:28
E-Mail Me. Russ
Mark
09-01-2003 11:23:29
If you are not going to work it install D21 plugs.
