2010 engine swap?
steve
09-01-2003 06:24:58
will a 45 combine engine fit my 2010?
Ive heard of a 165ci. and a 180ci. combine eng.
supposedly they fit? what kind of hp do they
have? any info may help
Doug
09-01-2003 21:12:41
 Re: 2010 engine swap? in reply to steve, 09-01-2003 06:24:58
First I don't have experience with the 2010 but I will share what I discovered with a 2520 gas.
I had a cracked block which needed replaced, when checking on a used block the only question I was asked was what the casting number was on my block. The block I purchased had the same casting number but was from a combine. After getting the block home and doing some preleminary checking I discovered that 2520 tractor sleeves didn't fit the block I had purchased. The block was machined for smaller sleeves, if I remember the block I had purchased was 180 CI while my tractor was 208 CI. Every thing else seemed to be the same. I did send the combine block back and found a tractor block. It just made more sence for me to use a block from a tractor.
Doug
