Hyd leak JD 70
farmmerbob
08-31-2003 20:21:19
Just purchased 70 JD discovered transmission & power shaft housing overfull & powr-trol low. SO my powr-trol leaks. after considerable time spent with parts, hyd, & service manuals am still at loss as where leak is. I suppose should start with powr-trol lift cylinder.
Has any body had similar experience?
John in IN
09-01-2003 18:25:43
 Re: Hyd leak JD 70 in reply to farmmerbob, 08-31-2003 20:21:19
I have repaired the lift cylinder gasket on my J.D. 50. Sounds like a good place to start. You have to remove the back transmission housing and when you remove the cylinder look closly at the gasket to see if it appears to be blown. Mine was. I would go ahead and replace the o-ring and seal on the lift piston also. Good time to get a good light and inspect your inner axle bearings and the rest of your rear end. Good Luck.
farmerbob
09-01-2003 19:02:56
 Re: Re: Hyd leak JD 70 in reply to John in IN, 09-01-2003 18:25:43
John: Thanks for infor, will give it a go before long. Sounds as though it may be fairly big job,but I am good at tearing things up. Thanks again: Farmerbob OK.
