Dubuque front end
tom
08-31-2003 09:01:54
Gentlemen,
The tricycle front-end on the MT has the notorious "shakes" when driving through the pasture [3rd gear] and even more so in final drive on the road. I have never taken the front end off of anything, and was looking for some direction in what I need to do/not do and what I should look for? I am sure some bearings and bushings are shot, but if someone could get me started, I can post back on the findings and next steps.
Thanks in advance and have safe Labor Day Weekend !
regards,
tom
Bob Collins
08-31-2003 13:51:39
 Re: Dubuque front end in reply to tom, 08-31-2003 09:01:54
Tom, Having just been involved with the steering on my M which is similar but different I would recommend checking the following;1) Connection of the steering tube to the worm shaft of the steering box, this is clamped by a 1/4-28 bolt and takes a lot of stress. 2) Free play in the steering gear box, this is easily adjusted per shop manual, but you may need to pull off the top and look at the worm for wear/damage and bearings that this shaft rides on. 3) Look for loosness in the bolts that connect the upper and lower spindles. All these places could be a bit loose and it adds up.
tom
08-31-2003 18:43:11
 Re: Re: Dubuque front end in reply to Bob Collins, 08-31-2003 13:51:39
Hey Bob,
Thanks for the info...your M is a wide front isn't it? I have already examined, adjusted and repacked with grease the steering gear-box, my problem seems lower where the lower spindle resides...I will look it over and good luck with the M.
regards,
tom
