WayneI don't disagree with your earlier post on what JD says in the parts book on the dipsticks and engine blocks for the 420/430. However, JR Hobbs writes that the new T10474T engine block was first introduced in the 440 series tractors was gradually phased into late 420 production, but it is impossible to tell just when that occurred. JR also claims that the new power steering system that did away with the flow divider valve showed up at sn 131818. I checked in the parts book and this particular sn is exactly like the parts book says. I personally think that when it comes to splitting hairs JD had to print the book and possibly it did not coincide exactly with when the new cart of different parts started to get put on at the assembly line. Also I know that all kinds of pieces get swapped around at the chop shops. I just returned from the barn to check on my little 420 green money hole. The sn shows a 420W with sn of 132100. It does have the new type power steering. Also the T10474T engine block is on it. This tractor was hauled out of Missouri and was in worse shape that some parts tractors. The only reason I decided to give it a home was because it was a 420W and had spin outs, 5 speed, live pto, and the late model power steering unit. The good part was that the tires held enough air to get the bones pushed on the trailer. This tractor could have been run thru a chop shop in its day but don't show any sign of it as I can determine. Anyway, something to think about when all the work is done and it is Miller time.
