J.D. Power Unit Model LUC /// NEED INFO
Gary F
08-30-2003 22:12:27
Pulled an old barn apart and found a John Deere Power Unit Model LUC ser#37845. It's a two cylinder with a clutch assembly unit and I wonder if restored it could be used for a buzz saw. What kind of application was it made for, what is the horse power and what about parts are they available any more. Is it worth a shot or should I give up the idea? All information would be appreciated.
Steven
08-31-2003 13:03:49
 Re: J.D. Power Unit Model LUC /// NEED INFO in reply to Gary F, 08-30-2003 22:12:27
The LUC was used on the 12-A combine. It's very much like the engine used in the LA tractor. It's a John Deere engine. And don't let anyone tell you it's not. Some think they were made be Hercules. The LUC has 16.5 HP and runs at 1850 RPM. The shaft coming out of the gear reducion runs at 795 RPM. You can get the operator's manual and part book from John Deere. You can get most of the parts for John Deere. Whever you do don't junk it. You or someone can have lots of fun with it. I'm sure it will run a saw.
