2240 loader
Earl
08-30-2003 20:17:10
What would cause a JD 146 loader on a JD2240 to shudder only when the bucket/lift arms are lowered? It raises fine in all RPM ranges and there is no noise; however, when it is lowered, with or without a load, it shudders. Note: the problem seems to diminish as it warms up. FYI, the fluid is at the proper level; although, I can only assume, at this point, the hydraulic oil in the tractor is the the "proper" weight and kind. Thanks in advance!
John
08-31-2003 10:14:33
 Re: 2240 loader in reply to Earl, 08-30-2003 20:17:10
I`m assuming you using a remote valve not the scv`s. My guess is the problem is in the valve bank. Possibly a collapsed or worn out spring. Swap the hoses between the boom and bucket valves and see what changes. May help in diagnosing.
Earl
09-11-2003 04:03:32
 Re: Re: 2240 loader in reply to John, 08-31-2003 10:14:33
Good Idea! Thanks!
