4010 OIL LEAKS ON LOWER DRAWBAR POINTS
JIM MALLANEY
08-30-2003 06:28:12
DOES ANYONE KNOW HOW TO GET TO THE OIL SEALS ON DRAWBAR POINTS TO REPLACE THEM. LEFT SIDE LEAKS BAD.
Mike j
08-30-2003 18:38:51
 Re: 4010 OIL LEAKS ON LOWER DRAWBAR POINTS in reply to JIM MALLANEY, 08-30-2003 06:28:12
I just put seals in my 4000 they have a new kind of bushing that has an o ring in that is a much better deal just take 1 in. pipe and stick it threw the housing to drive the bushing out on the far side then move to the other side and drive it out put in the new bushings with o rings in them this o ring will set on the shaft in a place that has been in oil so you might not have to replace the shaft you then put in the outer seals like before but they are heavier and more or less just keep the dirt out.
Jailkeeper
08-30-2003 12:11:01
Had a similar post on another forum this week. You can read some other suggestions there.
G-Man is right, the seals are a pain to replace because they are fairly delicate to install. If you do it replace the shaft and bushings too, or you'll be wasting your time.
G-MAN
08-30-2003 07:51:02
That's a notorious place for oil leaks on small-frame JD tractors. They're called load shaft seals, and they seal the shaft that controls the load and depth portion of the hitch valve. It's a shaft running crosswise in the bottom of the differential housing, and the ends protrude into that triangle shaped frame you see. The drawbar runs past it, but the frame is actually the connection point for your lift arms. They can be somewhat of a challenge to get sealed correctly, and you'll also likely need to replace the shaft and bushings, which aren't too cheap. I'd recommend getting yourself a service manual before doing anything else so you can see what you're up against. You may decide to let a JD shop or someone with experience with those seals do the job. I'm a JD tech myself, and even I hate doing those seals. The later large-frame tractors with the lip seals and needle bearings are a much better set-up, at least until it's time to get the lift links off the ends of the shaft...
