Can I do this?
parrothead
08-29-2003 22:16:28
I bought an engine for my 40C that was out of a 40 tractor. It now appears to be a 430 engine. The 430 engine has a craked head (knew about that) and I wondered if the stock 40 head on the crawler's old engine will work on the (I think) 430 engine? Any ideas?
Thanks
Mike M
08-30-2003 17:57:08
 Re: Can I do this? in reply to parrothead, 08-29-2003 22:16:28
The model 40 engine does not have a water pump
like the 420 and 430 tractors do. That makes the ports differant on the head.
Bus Driver
08-30-2003 16:05:20
What is the State where you live? I am in NC. I have a parts 40 with engine that supposedly was overhauled. When putting the tractor back together, evidently the clutch was not aligned and they tried to force it with the clutch housing bolts. The lower bolt hole is broken from the engine flange- the piece is there, not discarded. It is the side were the distributor is located- the right side. That bolt is stressed on a wheel tractor, but if I remember correctly, the engine on the crawler literally hangs from the upper block flange bolts. If so, the broken lower flange corner would not reduce the strength for the crawler application. Don't discard your old engine, it probably has some usable parts. Maybe we could do some swapping as I have an extra block for an M that the 40 parts probably will fit.
buickanddeere
08-30-2003 15:37:41
You may wish to stay with the 40 engine. The drivetrain was beefed up for the 420/430/440 power levels of 23% extra putt. Plus it will be worth little more as collectable. I don't have my parts CD with me but I think high altitude pistons were factory available, cost the same and would add a wee bit more snort and efficiency if you want it.
jocco
08-30-2003 14:03:38
no the heads wont interchange the blacks can be dry sleeved
parrothead
08-30-2003 12:43:49
 Re: Re: Can I do this? in reply to Brokenwrench, 08-30-2003 12:19:34
My original idea was to overhaul the original engine. It was severely stuck when I got the thing. I found out later that the reason that it was stuck was because there was a crack in the cylinder wall. When it sat for about a decade, the piston and cylinder wall became petrified into one nasty chunk of metal. I found a running engine with an external head crack and I thought that I could simply swap the good 40 head over to the 430 engine. I don't have the new engine in my shop yet. I'm anxious to compare the head differences. I might be able to have the cracked head repaired..... .
HerbN
08-30-2003 06:55:46
None of the part numbers match for either the 40 or 430, gas or all fuel heads. Can't tell you if they will work. Good luck.
Wayne in Tn.
08-30-2003 08:01:26
 Re: Re: Can I do this? in reply to HerbN, 08-30-2003 06:55:46
Parrothead, The heads will not interchange, the 40 has a 4 inch piston and the 420-430 has a 4-1/4 inch piston. The 420 and 430 engines have a water pump. About the only visual difference between a 420 and 430 engine, is the 420 will have the old type oil dipstick on the left side. The 430 will have the screw-on cap type on the right side.
Henry J
08-30-2003 09:39:53
 Re: Re: Re: Can I do this? in reply to Wayne in Tn., 08-30-2003 08:01:26
Wayne
Gotcha :) Somewhere along the line late model 420's had the same dip stick as the 430. I think I am right? Have you ever seen one of those?
Wayne in Tn.
08-30-2003 12:06:12
 Re: Re: Re: Re: Can I do this? in reply to Henry J, 08-30-2003 09:39:53
Henry J. No, the engine was changed at serial number 140000. 139000 and below had 420 serial plates and the bayonet dipstick on the left side. 140000 and up had a 430 serial tag and the filler-cap dipstick on the right side. However it is very possible someone over the years has swapped the engines, acutally I have a 420 at the present that someone has put a 430 engine in it. Also I would imagine there are some 430 tractors out there with 420 engines in them. Take a look at the parts book on page 10-2 it will show the serial number break between the two engines....The oil dipsticks are about the only differences in the two engines, the expansion plug in the rear and the tach. plug is different on later model 430 engines, the valve cover is a little different on a 420 and 430. The 430 engine has a stud where the oil filter base mounts. Also there is a difference in manifolds, but I can't tell what it is.
