720 DIESEL
Luke Erpelding
08-29-2003 19:47:15
WHAT WILL A 720 DIESEL WEIGH? I DONT THINK IT HAS FLUID IN TIRES. WAS WONDERING IF TO HEAVY FOR AN H@H TRAILOR WITH 3500# AXELS?
buickanddeere
08-30-2003 15:40:18
 Re: 720 DIESEL in reply to Luke Erpelding, 08-29-2003 19:47:15
Can't recomend 10,500+lbs on a 5000lb class three hitch. Not worth killing some innocent family on the highway.
52 A Boy
08-30-2003 10:04:26
I have a 730 Diesel with the square wide front, 16.9 38's and with 2 wheel weights on it it weighs somewhere around 8300#, so if you have a n/f you would probably be around 7500#, it would be to much for a trailer with just 2 3500# axles.
52 A Boy
Clooney
08-30-2003 04:02:24
Luke, a 720D is a load for my (2)- 7,000# axle trailer. Remember that (2)-3500# axle trailer rating included the trailer weight, so combined you will probably be well over 9,000#. A 520 gas is a pretty good load for a car hauling type trailer.
~My guess is that 3500# axle trailer only has brakes on one axle [most are like that]. That isn't nearly enough brake for the load you are planning on hauling. The other thing is the loading ramps, you will bend the ramps & ramp rests on most 3500# axle trailers...
Mel
08-29-2003 20:58:46
It weighs in at about 7100 lbs. I wouldn't move one very far on that light a trailer.
