Clooney!!
Dan the D man
08-29-2003 18:48:39
Clooney i did some of the things you said in your last message about my 50 D. Now its got to the point where it dosen't run properly. I pulled the choke out add it ran fine and elimate most but not all of the flame. I think i may have found the spot were it might be leaking from the manifold gasket but its right by the fan some i can't check it when its running. If its not that and its the valve spring how can i go about fixing that?? Do i take off the valve cover and tighten them or what??
Thanks
Clooney
08-30-2003 03:50:59
 Re: Clooney!! in reply to Dan the D man, 08-29-2003 18:48:39
Dan, on your statement " Now it's got to the point where it doesn't run properly"....If it doesn't run properly & you pull the choke out & it runs better you probably have a carb problem, or possibly an intake manifold leak.
~A leaking exhaust manifold gasket can cause the popping & fire out of the exhaust but probably not a poor running problem. [it will sound bad but not actually run bad]
~Lets go back to square one here so we are both on the same page.
~You have a popping & fire out of the exhaust?..... [correct?].
~Per your above, you also say it doesn't run good but gets better if you pull the choke out?..... [correct?]..... What RPM & load does it run poorly at?
~On the valves?,, pull the rocker cover off, then push on all the valves & see if any have any soft springs [it will feel easier to push on a soft or broken valve spring]. Compare all the springs, if they all feel about the same your valve springs are probably ok...Note: the valves must be closed [or all the way out] to compare the spring pressure so you will have to turn the flywheel until all the valves are up] ... To adjust the valves, just warm the engine up, then turn the flywheel until both valves on a cylinder are closed & the flywheel slot is running fore/aft [parallel with the ground]. Then adjust the valves until a .030" feeler gage will just fit between the rocker arm and the valve stem top. If you want to do them cold use about .032"...
Dan the D man
08-30-2003 09:54:44
 Re: Re: Clooney!! in reply to Clooney , 08-30-2003 03:50:59
Clooney,
I can tell you the exact RPMs but it was pretty low. When i idle up the tractor it got a bit better but not good. I have a DLTX 16 carb would that be the problem or do i have to take the carb off and clean it. The leak that i think i found is in the middle of the manifolds so I'm thinking that its the intake manifold right?? This winter hopefully i will get the proper carb for it then i won't have all this trouble HAHA.
Thanks
