530 PTO problem
DDR
08-29-2003 17:19:59
When I shut the tractor off and throw the lever, the starter won't turn over. It's all locked up. I don't know if it was like this when I bought it or after I replaced the axle bearings and seals. I didn't take anything apart back by the PTO clutch. Did I not get something lined up when I put the back end on? The foot lever acts like nothing is engaging either.
ChuckW
08-30-2003 04:13:40
 Re: 530 PTO problem in reply to DDR, 08-29-2003 17:19:59
does sound like the pto unit, for your interest there is a unit on ebay auction...under John Deere 530. Might want to pick up some parts..
Clooney
08-29-2003 17:51:52
DDR, it could be anything from a rusted up PTO clutch, to broken gear or shaft inside the trans, to you didn't get the PTO front to rear shaft lined back up when you put the tractor rear housing back on, to ???.
~The place to start is to pull the PTO rear housing off [clutch & all], then try to turn the clutch drum that's still inside the rear end housing [the front PTO lever MUST be disengaged]..If it turns then your problem is probably in the rear clutch area. If it won't turn you probably have a problem in the shaft coupling area or in the PTO drive/driven gears....If the clutch drum will turn, engage the front PTO lever & try to start it, if it will start your problem is in what you removed....
DDR
08-31-2003 17:33:29
 Re: Re: 530 PTO problem in reply to Clooney , 08-29-2003 17:51:52
I took the clutch all apart and all three steel balls were out in the case. I need to get new discs and rebuild it. Can I get all the parts from Deere? Any suggestions?
DDR
08-30-2003 15:11:20
I found my problem. When I tried to take the drum shaft out, it was stuck. I pounded it out with a rubber dead blow hammer and there was a 5/8" steel ball wedged between the outside of the drum and the bottom of the case. Do you suppose someone had replaced a bad bearing sometime and one of the balls got down there? It looks like I need to replace the clutch discs while I'm there. I put the shaft up in the tractor and it turns fine.
DDR
08-30-2003 10:17:56
I took it apart and the clutch drum does not move with or without being engaged. What do you suggest next?
DDR
08-29-2003 17:57:21
Thanks, I will tear into it Monday and give you a report or ask more questions
