730 PTO oil ??
mike-nm
08-29-2003 09:46:42
I was wondering what kind of oil should I use in my new 730 pto? also what about the hydro. lift 3 point ? also is there a drain plug on the pto body to change the oil? as I have just ordered my books from Deere, I would like to get a head start on things. thanks-mike nm
Steven
08-29-2003 10:09:50
 Re: 730 PTO oil ?? in reply to mike-nm, 08-29-2003 09:46:42
I always use John Deere Hy-Gard oil in the PTO clutch and hydraulic system f my 520 and 620. The PTO has a oil level check plug at the back end, and a drain plug at the bottom. The hydraulic system and 3 point hitch use the same oil. It has a dip stick and a drain plug at the bottom. If your tractor has power steering. It has a pump in back of the engine fan. Use John Deere power steering oil in it. The hood has a plug that can be removed. The dip stick for the power seering is under it.
