44 A runs rich.
JDJACK
08-29-2003 08:08:21
Have 44 A that runs rich at wot with no load, had on baker fan and runs good with load screw set at 3/4- 1 turn, but with no load has a rich miss and fouls plugs.
Idles good. Had carb gone through about 3 years ago, passages were drilled (I believe). engine is in good shape new pistons and rings and bored 3 years ago. Should the idle screw be set at wot no load, and load screw set under load? timing is set correctly. IF load screw is leaned it runs faster and has no power when tractor is pulling. Thanks for any help JDJACK.
Lee
08-30-2003 00:42:23
 Re: 44 A runs rich. in reply to JDJACK, 08-29-2003 08:08:21
Both the idle and load mixture settings do have an effect on the other. So true idle setting must be done at idle speed and no load, but it's OK to turn it in or out a little at WOT under load or no load to see if it helps - just remember where it was in case it don't idle again.
Likewise you can keep turning in the idle screw if you open up the load screw at idle, but it chugs black smoke if you touch the throttle. Somewhere in between all that is the settings you are after - good luck.
You should be able to kill the tractor by leaning either screw. Likewise you should get heavy black smoke opening either screw. If not, then some passage is obstructed and the carb needs going through in order to find and clear it. Only when both screws can kill it and smoke it bad do I consider I'm done with the carb. Tweaking in the field is the only way I know to set it finally.
I would try to open up the idle screw some and see if that won't allow you to close the load screw some to get rid of the noload, hispeed fouling.
Deere Moe
08-31-2003 06:06:05
 Re: Re: 44 A runs rich. in reply to Lee, 08-30-2003 00:42:23
My 49 A did that and I tried everything to adjust it out. Found that the govenor rod was extended too long (about 1/4 inch long) which made her run unevenly down the lane and made her eat some gas- that one adjustment made the tractor run like new again and be sure to have proper plugs in her.
Moe
