JD 110, hard to start
Charbaugh
08-28-2003 08:35:11
Rebuilt 10HP Kohler on a JD 110. I'm not to sure why, but for some reason, this thing is hard to get started. But once it's started it runs fine. I think it has something to do with the carb. Does anyone have a good technice for tuning a carb? I'm wondering if the points have anything to do with it, I never replaced them, i just cleaned them up really good.
Donny-B
08-29-2003 15:29:33
 Re: JD 110, hard to start in reply to Charbaugh, 08-28-2003 08:35:11
Corey, When replacing points its a good practice to use a timing light to get an accurate setting. Points are not made with the contacts exactly parallel or "true" to each other. A small variation can cause poor starting. Also, did you re-torque the head gasket? Kohlers are prone to head gasket failure and a leakey gasket along with the ACR (automatic compression release) will make them hard starting. Good luck.
buickanddeere
08-28-2003 15:56:06
One of my boy's 110 becomes hard to start and misses once the fuel tank gets below 1/3 full. Sometimes the gas cap has to be removed and some air pressure used to force gas into the carb. The away she goes on the 1st try. Rebuilt the entire carb with all new parts but missd what ever the problem was. Discovered it won't run at all with a gas filter added inline.
phil
08-28-2003 10:08:48
Had similar experience with my 1969 8HP 110. I had to control the choke & throttle very carefully to get it to start. In my case, it was the points. I had cleaned them, spaced them, inspected them, they looked good. But I finally put in a new set. After that, no problems, it would start from any throttle position.
charbaugh
08-28-2003 11:28:43
 Re: Re: JD 110, hard to start in reply to phil, 08-28-2003 10:08:48
Thanks, I just ordered new points and a feeler gauge.
Corey
SamV
08-29-2003 04:52:19
 Re: Re: Re: JD 110, hard to start in reply to charbaugh, 08-28-2003 11:28:43
Don't forget a condenser tooo... They can cause all kinds of headaches and for the dollar or 2 they cost it is well worth putting it in.
Sam V
