S. Conner, you ask....."One thing I am wanting to know is how does the electrical system get 12 volts for the lights and accessories from a 24 volt system? Is there a resistor somewhere that isn't shown on the electrical print."-----Answer..It doesn't get 12 volts from the 24 volt part of the system...[no resistor used] ~Basically your tractor has 3 electrical systems on it....A 12 volt positive ground system using 1/2 the batteries at positive ground,,, A 12 volt negative ground system using 1/2 the batteries at negative ground,,, & a 24 volt system using all the batteries is series. ~The tractor has an isolated ground 24 volt system, That means that both the starter & generator are completely isolated from the tractor frame [& chassis] so no part of the 24 volt system uses the tractor frame [or chassis] for either a power or a ground circuit. Each of the 12 volt systems DO use the tractor frame [or chassis] to carry power for either power [one 12v side], or ground [other 12v side] circuit. ~The key to that system is a simple little wire running from the 2 [center most] posts between the batteries to the tractor frame. Without that wire the system wouldn�t have either 12 volt system. ~What you have is one 12 volt negative ground system that runs from the positive most battery post in the battery chain to that little wire between the batteries, about � the lights & accessories are on that system,,,,, You have one 12 volt positive ground system that runs from the negative most battery post in the battery chain to that little wire between the batteries, that runs the other � of the lights & hopefully the other half of the accessories,,,,, You then have a 24 volt system, that runs from the positive most battery post in the battery chain to the negative most battery post in the battery chain [all batteries in series for 24 volts]. Both the generator & starter are electrically isolated from the tractor frame & chassis so the starter is powered from the most positive battery post in the battery chain to the most negative battery post in the battery chain. The generator then charges ALL the batteries together as a 24 volt system from the most positive battery post to the most negative battery post. Simple as that! ~That 12/12/24 volt system is simple & functions extremely well IF all the light & accessories loads are kept even & matched on both 12 volt systems. The problems arise when more accessories are added to one side or other of the 12 volt systems. If electrical loads AREN'T kept pretty well matched then one side of the system doesn�t charge completely & that can spell trouble for starting, as the 24 volt part that uses ALL the batteries in series can�t use the dead battery in the chain & then won�t receive it�s full 24 volts. ~Simple when you think about it.. Difficult when you just think of it� Questions�[email protected]
