JD 4250 POWER SHIFT
VINCENT
08-27-2003 19:38:29
On my 4250 15 speed power shift, only the even gears work, all of the odd gears slip bad. Checked out the traction clutch and it is in good shape. Any ideas?
chris
08-28-2003 21:15:32
 Re: JD 4250 POWER SHIFT in reply to VINCENT, 08-27-2003 19:38:29
Try input planetary or Clo/Bhi housing. Its the last thing to remove in the clutch housing.
VINCENT
08-28-2003 16:11:33
Chris, I had the tractor split, and found some o- rings in the clutch oil manifold blown out which I thought was the problem, but it wasn't. I looked though my tech manual-1353 and can't seem to find anything refering to a Bhi pack, maybe in the book it is refered to under a different name. Could you fill me in? Thanks, Vincent
chris
08-27-2003 19:58:32
The problem is the Bhi pack, and how did you check out the traction clutch? Requires a split job at the engine/clutch housing to fix. chris
