Help with vandalism damage
tomp
08-27-2003 18:22:20
Unfortunately my 301a(like 2040) was vandalized.
the damage done was broken gauges, pulled wires, gasoline in radiator and poured down exhaust.
I won't go into my anger and disgust with the vagrants.
I have begun to change all fluids flush etc.
my question is what should I do about the gas that has been poured down vertical exhaust.
When I shine a light down exhaust I can see a level about halfway down. I would like to leave exhaust manifold on since removing it I believe would be a last resort as It is very rusty.
thanks
Steve in Mo
08-28-2003 03:43:32
 Re: Help with vandalism damage in reply to tomp, 08-27-2003 18:22:20
Get ya some mean roosters. We had to have a new tv antenna installed after storm damage. Went to the Radio Shack store to pay the bill and the service tech said that my rooster attacked both he and his helper while they were there. Man I sure would liked to have seen that. Steve
Jack
08-28-2003 10:08:42
 Re: Re: Help with vandalism damage in reply to Steve in Mo, 08-28-2003 03:43:32
We had a duck once that could put a stranger back in his truck in a hurry.That sucker could hurt you with that beak.
TOM
08-28-2003 04:11:08
Can I borrow those roosters and tie them to my wife's car when she want to go SHOPPING AT THE MALL !!!
Pete/ME
08-28-2003 03:39:59
All good intentioned advice, some a little scary though. DO NOT move any parts that could cause friction heat or a spark. A gallon of gasoline=1 stick of dynamite, the enclosed spaces of the manifold/engine could create one huge hand grenade. Siphon or pump what you can--stick a plastic hose down the exhaust as far as you can. Open the base plug and drain what's in there. I think it would be best to dilute what's left with fuel or oil. Just pour it down the exhaust. Then start breaking down the engine. Be careful.
Bob
08-28-2003 00:24:01
Remove battery, and keep any other possible sources of ignition away! Remove injectors (It's diesel, I assume?) Put fresh oil in crankcase. Pull tractor with another machine, slowly at first, with the vandalised unit in a higher gear, until the gasoline is blown out of the exhaust, and the cylinders, if any got in there.
Be carefull, and be prepared for a fire, should some weird occurance torch of the gasoline.
david val
08-28-2003 01:35:03
 Re: Re: Help with vandalism damage in reply to Bob, 08-28-2003 00:24:01
if it's diesel, i don't think that removing the exhauset manifold should be a problem (together with muffler). it will be much safer to start the engine without gasoline present at the exhaust way.
david
Jailkeeper
08-27-2003 21:16:59
If there is liquid in the muffler, then there is bound to be at least one cyliner full of liquid. You will need to pull the spark plugs or injectors and crank the motor by hand SLOWLY to expel any liquid inside the cylinders. Doing this you shouldn't have to remove the manifold.
David Bacon
08-27-2003 20:26:44
Could you perhaps take a 1/4 inch soft hose and fill it with gas---hold your thumb over the lower end (well below the exhaust) after inserting the other end. If you live anywhere near NE Iowa you are welcome to use my air powered pump--it will pump acid, oil, water, gas --you name it. A cheap sand blaster that you insert the end into the sand will work also to insert down the exhaust. Good luck and perhaps some day we can understand those type of persons. Dave NE Iowa
another doug
08-27-2003 19:54:00
Tomp , don't crank it with the starter, you could bend a connecting rod, gasoline might evaporate? maybe loosen the bolts if they will turn easy, don't want to break off a stud...sorry about your tractor, i hate idiots
