Clooney Help!
Dan the D man
08-27-2003 10:00:59
Clooney it's my 1950 D. Its acting up again. resently at night I've notice that a blue flame came out of the muffler every so often. Now it comes out every second or two and it only did it at full throttle before now it does it from 3/4 to full.I've tryed adjusting the carb but the more i turn the needle in the worse it gets and it one full turn from coming completly out. Anything you got on this problem came be useful and could yo uuse lots od detail or step by step please and thank you.
Clooney
08-27-2003 10:34:59
 Re: Clooney Help! in reply to Dan the D man, 08-27-2003 10:00:59
Dan, other than the obvious like a bad spark plug, or sticking valve, or carbon tracked distributor cap you might want to check for a leaking exhaust manifold gasket or cracked exhaust manifold. If the gasket or manifold is allowing outside air to be sucked into the exhaust system it will pop fire like crazy.
~How does it run under a load? If it runs pretty good then you probably don't have a mechanical problem but more than likely an air leak or mixture problem...
~Does running it with the choke partially on help diminish the problem? ~Most of those old D�s I have had did have some kind of an exhaust manifold leak so start there�..
