JD 110, Kohler K241....black smoke
charbaugh
08-27-2003 08:55:45
I finally got my newly rebuild engine to start. It runs great, idials fine. The only problem is sometimes it starts with black smoke. I think it may be because it's flooded, whould that cause black smoke? I can start it about 5 times and it only smoke 1-2 out of 5 times. What else could it be?
Thanks,
Corey
Henry J
08-27-2003 10:48:43
 Re: JD 110, Kohler K241....black smoke in reply to charbaugh, 08-27-2003 08:55:45
Char
You said sometimes. That could mean that on an intermittent bassis your float needle valve is letting gas in the carb after shutdown. If so it will puddle up somewhere in the intake (I dont know exactly how your intake is configured). Most of the intakes have a drain in the bottom under the carb, but I have never seen one that would actually drain in a motor that has some age on it. The ones that I fixed that did this and the owner did not want to spend any money on it simply had one of those plastic shut off switches put in the fuel line and they turned the gas off after shutdown. Just a thought
Jake
08-27-2003 10:19:04
Some of those small engine do that. Remember, when you turn off the key it just kills the ignition. The enigne coasts to a stop but while doing that the carburetor is still feeding fuel through the enigne so everything is covered with fuel when you try to start it immediately after that. My 5 cents worth.
charbaugh
08-28-2003 07:06:35
 Re: Re: JD 110, Kohler K241....black smoke in reply to Jake, 08-27-2003 10:19:04
Thanks for the replys. What you all are saying, makes allot of sense.
Thanks
