730 DIESEL QUESTION
JON
08-26-2003 20:07:54
I have a 730 diesel that I just rebuilt and I have a infrared thermometer and the temp from on side to the other verys 45 degrees F on the exhaust manifold. I have JD 70 diesel that has never been touched and the temp. on it is with in 10 degrees.
I did the pump and injectors when I rebuilt the tractor. Any ideas whats going on? thanks
Clooney
08-27-2003 04:03:42
 Re: 730 DIESEL QUESTION in reply to JON, 08-26-2003 20:07:54
JON, that doesn't surprise me on the exhaust manifold as the L/H side comes to the right side before exit. Try your heat gun on the cylinder head.
~If you are still worried about it, pull both fuel injectors out & turn them around, then crank it & watch the spray pattern. It should look even & about the same from side to side. You can then rig a catch tube to each injector & crank it until a measurable amount of fuel is in each tube, then use a precision measuring bruit (sp) & measure the amount sprayed by each injector & compare the sides�..
~CAUTION: don�t use your hand to check the spray pattern as those injectors can & will inject the fuel right through your skin!!
Mel
08-26-2003 21:22:29
I had a 720 that I had the pump and injectors gone through on also. It ran and pulled good but one day when I went to start it, it sounded like it was missing on one cylinder. It was low on fuel so I thought it had gotten air in the line and thats why it was missing. I bled everything down and it still sounded like it was hitting on one. After checking the manifold temps I found one side a lot cooler than the other also. I took the pump out again and took it to the diesel shop for them to check. They found a broken spring on one side. Put it back together and ran good after that. I guess they are professionals but things can still go wrong with parts.
