40T 412 Bottom Plow
Daniel
01-18-2004 11:26:46
I am presently reworking the two bottom plow that came with this tractor from the dealer. It is 412 2 bottom plow. I was not sure of the shares, shins, or moldboards to replace the originals with. When I removed the moldboards and cleaned them up I read this stamped in the back. HS316 JD.
The operators manual to the 412 says that the plow houl dbe a 2 bottom 14 max. Why does it have HS316 16 inch bottoms on it.
The only reference to the HS316 in the operators and parts book for the 412 calls it special bundle and it stands for high speed 16 inch.
If any of you guys have infomation to share on this subject it would be great.
Thanks,
Daniel
MIKE HANLEY
01-18-2004 13:41:05
 Re: 40T 412 Bottom Plow in reply to Daniel, 01-18-2004 11:26:46
Here's just a guess. And it is just a guess. Someone reto'd later tectnology. Just like a narrow share was availble and recomended where crop roots were not a problem (Say oats stubble), as they penetrated easyer and pulled lighter then full cut shares. (Full cut needed for say Alfalfa.) A 14" bottom was Recommened for slower speeds down to 2 1/2 MPH and deeps of 6" to 8", The same bottom in 16" was recommened for speeds of up to 5 and 6 MPH and to depths of 12". This info comes from a John Deere plow book dated 1974. Based on that, My guess is that someone wanted plow deeper then the standard 6" depth of the era of the 40 tractor and the 412 plow. Maybe the guy that had the plow before had easy plowing soil or a bigger tractor pulling it then a 40.
