Clutch/Shifting Problem
Pete
01-18-2004 11:06:18
Replaced the clutch disk on JD 2010. Disk fit on transmission shaft properly. Tractor will not shift into gear, get alot of grinding. Have tried starting tractor in gear with clutch pedal pushed in, tractor moves. Checked to see if clutch pressure assembly is releasing and it its releasing. The pressure plate must not be disengaging from flywheel. Split tractor again and put some grease on transmission shaft. Still the same problem. Any ideas?
Bob
01-18-2004 13:02:25
 Re: Clutch/Shifting Problem in reply to Pete, 01-18-2004 11:06:18
1.) Lined clutch plate installed backwards. Even if there is a sticker, or other mark on it, it could be marked wrong.
2.) Pressure plate fingers not properly adjusted, so plate does not release evenly all the way around, or pressure plate warped.
3.) Warped lined plate, lining not riveted evenly on lined plate, (Check thickness of lined plate at multiple points). Lining O.D. too great, and dragging around outside periphery. (I just had to split a 2010 twice last fall because a lined plate from and UNNAMED AFTERMARKET SOURCE had lining with a slightly larger OD than it should have had).
4.) Bent transmission input shaft.
