John T
08-26-2003 05:26:50
Re: Implement selection for '35B in reply to Wind, 08-26-2003 04:17:04
Mornin Wind, Actually its a great idea to use the old girl a bit under a load rather than have her set around and let seals dry out and crud and varnish accumulate. As far as your questions if it were mine (I have a 38 B) I would use a 2 - 12 plow if I intended to plow at a decent depth in varying soil conditions and types,,,,, ,,,pulling that cultipacker isnt much of a load and should be no problem,,,,,a sickle bar, even a 7 ft., unless in heavy wet tall grass like fescue etc., isnt too bad a load on that B and I'd use a 7 versus smaller for lighter duty like clipping pasture etc.,,,,, On that mower, if youre going to actually be "brush hogging" in heavy thick grass or brush, Id use more like a good sharp 4 or 5 ft max (depends on the stuff you're mowing) unit as opposed to a 6 ft. If its only light trim duty you may get by using a 6 ft, but that would be too much of a load if cuttign brush or heavy grass for sure. Good Luck n God Bless John T Nordhoff
