I hate to even post, but I gotta. Mr. Hanley, first, slow down a second, and reread your post. Most of what you posted does not make sense, granted I have posted a few things that were not totally correct, and had to go back and re-read it and re-post it to make it make sense. Fact: The fuel transfer pump is a gear pump, and all gear pumps will increase flow at higher RPM's. Pressure rises when there is a relief valve installed in the system, stopping the flow and causing the pressure to rise until the relief valve opens, causing the flow to run through, and keeping the pressure constant. Therefore you would have to restrict the flow to cause the pressure to rise, or change the pop-off pressure in the relief valve. Why do you think the later models had the relief valve put in?? To keep the pressures constant and to prevent to much pressure in the bridge. I put a transfer pump on the stand yesterday and at slow idle it was putting out about 20psi, crank the rpms up and it was hitting pressures well above 150psi, with out any machining. Fact rpm's do make a difference. There are no differences in the later transfer pumps and the early ones, sure the housings are different, due to the way they are mounted, but if you do not beleive that, go and print out the parts pictures for all the 2 cylinder diesels and look at the internal parts, they are all the same, have a ball and a spring, no pistons. The piston is in the relief valve setup on the bridge. I am not barking at you, I do think you have a lot of your system confused, as to where parts are and what they do. The early tractors had 10mm pumps, and the later ones had 13mm pumps. True they do not deliver any more cc's of fuel with the racks set at 10, but you change them to 15 and there is a difference, like 25-30 cc's more. I have run them myself on the stand and seen the difference. If your fuel is foaming, you wont have any power, true, most likely it wont hardly even run, put air in a diesel system, it wont run good either, if at all. Changing the rack setting will increase your horsepower, I have run several tractors on the dyno and have changed it and seen 15-20hp increase when the rack is able to open on up. I know they guy you talked to, Ive talked to him several times, even did a fuel setup for me once, heard the same story he told you, and I was not happy with the results of his modifications as there were no improvements, not saying that he is a bad guy, and like I said this was on one tractor, there may be others who had better luck and better results. I do not know. Good Luck Gpower
