D JD spark plugs
Randy P
08-25-2003 20:17:58
Whats a good spark plug to put in a D JD (1929) thats available..
THANKS
Randy
Spokerd1
08-30-2003 06:16:10
 Re: D JD spark plugs in reply to Randy P, 08-25-2003 20:17:58
I have a 1929 D and have excellent luck with the Autolite 3095 and the Motorcraft F-11. The Champion A25 plug will not last in my D. The Champion gas fouls to easy. My 29 D seems to starts easier on the Motorcraft and Autolight plugs.
Duane Larson
08-25-2003 21:02:03
Randy P,
Your D came with Champion #7 pipe thread plugs, and the current version of that plug is the Champion 525. If you like other brands, the Autolite 3095 is an alternative - AC Delco does not make a pipe thread plug any longer. An alternative is to find an adapter which will convert a 1/2" pipe thread to a modern plug (14mm or something).
I like two-piece take-apart plugs, and an appropriate plug would be the Champion 31, which may be available from some of the old plug dealers - but it is not cheap. While it is not exactly correct, the Champion X plug (used in Model T's) is being remanufactured by Champion, and that is a two-piece plug which should work in your D. It's part number is Champion 425, but is is not cheap either (about $25 or so).
