daveo, Since you asked, here is the "rest of the story". Your plug is 7/8" x 18 threads/inch. A little history - most plugs were made in France around the turn of the century, as they had the best material to make the insulators (which was THE key to making plugs). The prime spark plug mover/shaker in France was a fellow named Count DeDion, who declared the standard thread size would be 18mm. Meanwhile, in the US, with auto production headed straight up, the American Licensed Automobile Manufacturers (ALAM, forerunner of the SAE) chose the 7/8-18 thread as the standard in 1908. However, along comes Henry Ford in 1908 with his Model T, and Henry has an intense dislike for metric, and since he didn't belong to ALAM, he chose a very common thread pattern - the 1/2" gas pipe thread - for his Model T. Since he built so many of those, there ended up being three main thread patterns (two standards and one non-standard) - 18mm, 7/8-18, and 1/2" pipe thread. The first to go was the pipe thread, as it was not conducive to high compression engines (Ford went to a 7/8-18 plug in the Model A). Then, due mostly to size and cooling considerations, the 7/8-18 plug was dropped (by JD in 1939), but the 18mm plug remains today as a commonly used plug.Want to learn more? - the Spark Plug Collectors of America (SPOCA) just had their annual meeting at the Portland, IN show - contact me offline for info re SPOCA. Incidently, your tractor came originally from the factory with either Edison-Splitdorf Z19 or Champion 8ComC plugs. Neither are available through normal channels any longer, but some plug collectors have some available. They are both two-piece take-apart plugs. More than you asked for, huh?
