70Dand 720D Pony Motor
John in IN
08-25-2003 19:12:22
What is the difference between a 70 and 720 pony motor head if any?
Clooney
08-26-2003 03:12:00
 Re: 70Dand 720D Pony Motor in reply to John in IN, 08-25-2003 19:12:22
John, not much. The 70D & early 720D uses about the same pony motor. The 720 uses a different pony trans control & compression release set-up. The Late 720D also uses an oil pressure controlled pony fuel shut-off & different pony oil pressure light set-up. I think there was a slight carb difference in there somewhere also....
Tracy Redd
08-25-2003 19:35:53
70D and early 720D pony motor head are same.
same casting #
Late 720D and 730 are different than 70D and early 720D because they are little bit bigger.
I have a 2 heads for pony motor if you are interesting.
John in IN
08-26-2003 20:03:59
 Re: Re: 70Dand 720D Pony Motor in reply to Tracy Redd, 08-25-2003 19:35:53
I might be. I am not going to tear down until winter. I hope I don't need any, but if I do and you still have them I'll get in touch. Thanks, John
John in IN
08-26-2003 20:03:26
I might be. I am not going to tear down until winter. I hope I dont need any, but if I do and you still have them I'll get in touch. Thanks, John
