440 oil pressure
gil
10-20-2003 20:03:49
On a Dubuque gasoline engine, has anyone compared the oil pressure at the oil filter with the oil pressure at the front of the block where the hour meter sensor screws in? I have a 440I with a remote oil filter and direct read oil pressure gauge. Recent rebuild. 4 washers in the oil pump. Oil pressure at the filter is low, but at the front it is OK. Not sure if I change the gauge hookup and quit worrying, or need to do something more.
MIKE HANLEY
10-20-2003 21:30:19
 Re: 440 oil pressure in reply to gil, 10-20-2003 20:03:49
We need someone with JD Tect manuel for a 40 to jump in here. The last Tect manuel SM2019, for Dubuque tractors just states that the LUBRICATION SYSTEM is the same as on the 40 serirs tractors and you should refer to that manuel SM2013. The first Dubuque engines had a mecanical gage that screwed into the oil filter housing. On the 430 (serial# 140000) they went to an electrictral sending unit at the oil filter houseing and put an electrictal gage in the dash. When our 430's gage no longer worked, I thought I would save a buck and just get the mecanical gage from JD for the 40 420 and run a copper tube from the filter housing to the mecanical gage in the dash. Well it maxed out all the way over to high. When I had the 430 in to overhaul the engine, they put a master gage at the filter housing and they said it was right on. Where the gage reads now is what we call normal. I would put on a master gage at the oil filter housing after finding out what is the proper pressure.
