Ideas to work '35B
Wind
08-25-2003 07:09:29
Now that the tractor is all done and running well, I feel the need to work it some. Some ideas that I have had are geting a pull type gyro mower to keep the brush dowm around the place. How big could I go with one of these? I was thinking that a 5 footer would do nicely, is that too much for the tractor? another thought would abe a sickle mower, maybe a #5? Or I could pull some wagons for the guy that own the farm around me in the fall. Just feel that working it would make it run even better and give me some satisfaction and seat time. Plowing the garden won't even get it heated up, but I would like to find a plow to do that also. Also, the guy that farms around me has about an 8' rolling cultipacker. Could use that to break up the clods in the garden after plowing, without the cultivator tines down, but that might stretch the little thing a bit. Any ideas are appreciated.
Bill in Indiana
08-30-2003 11:18:09
 Re: Ideas to work '35B in reply to Wind, 08-25-2003 07:09:29
I've got a '48 B with a 7 foot No. 5 mower. It works the tractor real good after mowing 5 acres of pasture.
A No. 5 is fun to use if you're out in the open without a lot of stuff to mow around. With all the trees we've got, it's a pain to have to stop and start without live PTO.
DP
08-25-2003 13:51:34
Hooked my 38 B up to 18' spike tooth harrow this spring. Was real impressed with how good it handled it.
DRL
08-25-2003 09:39:57
Glad you got your B up and running. All your ideas sound good. Not sure what capacity is needed to do some of what you said, others will have a better idea. Just be real careful if you decide to bush hog. Those small PTO shafts don't take much abuse. I've got a '37 A that someone tried to bush hog with. The PTO shaft is now twisted and bent. The splines look like the inside of a rifle barrell. I agree that is good for the tractor and the operator to get out and work up a little "sweat," but don't over extend the ole girl!
