720d Power Steering woes
Tom in TN
08-25-2003 06:09:25
I saw a string here about a P/S problem on a 60. My 720d has a similar problem with the p/s fluid running out. Is there a vent for the p/s on the 720d? Where? Here's the story: Last time I took it out, I got it back to the barn an hour or so later and it looked like milk running down from above and dripping from the fuel filters. The p/s dipstick had no fluid on it at all when I shut it down and checked it. I use the right p/s fluid from deere. I've had it since Jan, and am still finding it's "personalities". I'm kinda new at this, and any help is appreciated.
Clooney
08-25-2003 06:45:19
 Re: 720d Power Steering woes in reply to Tom in TN, 08-25-2003 06:09:25
Tom, your P/S system has a vented filler cap [it's a porous bronze affair in the very center of the filler cap, probably almost plugged as most are]. That vent doesn't have to pass much air, all it has to do is allow the P/S oil & air above the oil to expand & not pressurize the low side of the system.
~In your case you could have a plugged vent causing your problem but I doubt it. The usual cause of a problem like yours is either moisture in the P/S system oil, or a leaking pump or bolster seal allowing air to be sucked into the P/S system.
~You might try cleaning your cap vent [bronze center]. Don�t scrape at it as that closes the porous pores of the bronze. ~Try soaking the filler cap in lacquer thinner overnight to see if that will dissolve some of the crud plugging it. To test it just put the cap end into a bucket [or jar] of water, then close the side holes on the filler tube with your fingers or tape, then blow lightly into the top end. If you see bubbles in the water it�s passing air.
Tom
08-25-2003 19:37:28
 Re: Re: 720d Power Steering woes in reply to Clooney , 08-25-2003 06:45:19
Wow, talk about quick responses! I appreciate it sir; I cleaned up the pump real good with some purple de-greaser, and could'nt see anthing obvious from there, it seemed like it was coming from over top of the pump, like maybe a line or connection, but I just didn't have the time to dig into it. I will MAKE time next time since I know better now what to look for. Im thinking about pressure washing the motor to get the goop off (did I mention it "slobbers" BAD?). Anything I should know about that could make my life harder than it has to be? (Hidden holes or connections?) Someone said to do it while the engine is running but not real hot. What do you think about that? Don't wanna mess up three things trying to fix one, do I?
Clooney
08-26-2003 11:35:37
 Re: Re: Re: 720d Power Steering woes in reply to Tom, 08-25-2003 19:37:28
Tom, pull the hood nose off. Maybe you have a leaking [seeping] pressure hose or loose connection at or in the gear area.
~I'm not a big fan of pressure washing a 2-cylinder diesel unless you are about to overhaul it. Those old beauties aren't that well sealed & you will blow water into the pony clutch, pony trans, pony distributor [expensive], under the compression release seal, into the flywheel cover, probably through the shift area & into the trans, the list goes on...
~Wash it with a mixture of kerosene & diesel, [do that a few times], then soak it down good overnight, then hose it off with low pressure hot water the next day�
~If you do pressure wash it be sure to use it under load for a few hours to dry it out, don�t just wash it & park it�
Tom in Tenn
08-29-2003 10:11:39
 Re: Re: Re: Re: 720d Power Steering woes in reply to Clooney , 08-26-2003 11:35:37
Kerosene and diesel bath? that is interesting. Who'da thunk it? That won't strip the paint off like the "degreasers" either, huh? See, Im wanna be like you when I grow up.
~Walk in peace~
