1020 - seized HELP
Matthew
08-25-2003 05:54:00
I had my 1020 diesel engine completely rebuilt about 2 years ago. New pistons, new main crank, bearing, new oil pump, everything.....
A few weeks ago, I was pulling stones out of the woods and got stuck backing up a hill with the front of the tractor on a tree. I let the front rest on the tree and the fan blade cut into the radiator, leaking the cooling fluid out. After jacking the frame up hill, I was able to get it free. I didn't know that the radiator was damaged or leaking. I then made the big mistake - I started the tractor and ran it back to my house.
I made it almost all the way when "she" the engine started to make an odd sound. She stopped all by herself, not a quick, sudden stop, but a slow dying down and a big puff of smoke came out of the tube that runs from the valve cover.
I let it sit for a few hours and then tried the ignition to see if she was completely seized. When I tried, she turned over!
Here's my question - should I run it, should I take the head off and see what happened? SHould I pull the engine and take it back to the shop? I changed the oil and the filter - oil smelled burnt.
I'm hoping that with a new rebuild that it may not be too damaged, but I don't know.
Anyone have anything like this?
davidval
08-25-2003 11:29:14
 Re: 1020 - seized HELP in reply to Matthew, 08-25-2003 05:54:00
probably the pistons seized in the cylinder liners. it's almost certain that pistons and liners are in bad shape, but you have nothing to loose, try to start the engine and if it works fine you're in luck. if not (i.e. engine knocking, high oil consumtion, low power, coolant in oil or oil in coolant etc.) pistons and liners must be replaced, rods checked and very important to check the head, valves and valve springs (sometimes springs weaken from the heat). david
