Can this be?
Ron
08-24-2003 19:29:04
I'm the one with the 60 that got water in the oil. I took the head off and really did'nt see anything obvious (having the head decked for safety). I noticed that coolant seems to be coming up through the hole that is in the bottom of the cylinder on #2. I don't think it is just gathering there but is actually comming up through. Is this possible or has anyone had any experience with this? I took the plug out of the bottom and dont see anything. Is is suppose to be a plug or a valve?
Look forward to your comments.
Oh yea, if it is comming up from that hole what is a guy to do??
help and thatnks
Clooney
08-25-2003 03:28:31
 Re: Can this be? in reply to Ron, 08-24-2003 19:29:04
Ron, anything is possible. There can be porosity in any casting.
~Look closely to see if that cylinder has been sleeved at one time. Sometimes the sleeves don't seal very good at the spark plug holes or petcock holes. If it's leaking at a sleeve to petcock hole you can try a little longer [deeper] plug that actually threads into the sleeve a little. ~When you find & verify your leak, let us know what is actually leaking?
cole in mo.
08-25-2003 00:05:12
Ron, the block on your 60 is the same as an A, that hole was for a compresson release. they done away with that on the I think real late As and the 60s and put in a plug. if you removed the drain plug you shouldn't have any water in the block to come up through that hole. my guess is the water is just sitting in the recession. turn the engine till the pistons are midway in the cyls. with a good strong light look at the top of each bore just off center where the center head stud goes in, you may find a 1 to 1-1/2 inch crack there. this happens when sombody over tightens the head bolts. also run each piston all the way back and check each cyl wall all the way around for freeze cracks. have you had the head magnfluxed with the valves out? maby somone else can offer better advice.
lowrey
08-25-2003 06:11:51
 Re: Re: Can this be? in reply to cole in mo., 08-25-2003 00:05:12
We worked on a 60 for a guy that had the same problem , he had the head redone and put it back to gather and it still leaked. He brought it to us and we tore it clear down. Took the block to a machine shop , they hot tanked it and checked for cracks and found none but while it was setting on the floor with the head side down cracks started to show up around where the head studs screw in. they where real hard to see. the block was junk.
