2 row corn planter
Gary
08-24-2003 15:32:23
I have a 2 row corn planter made by John Deere. I went to the JD web site to ask information on what type of planter I have. Even though I sent a decription of this planter to them, I receive an E mail from the ( within an half hour ) and a picture of a 71 flex planter. After sending them a picture of what I have I haven't heard from them for a week.
I am hopeing someone can help me. I have a adjustable width 2 row planter. The best as I can figure it should have 2 6.00X16 tires on spoked wheels. It has 2 large cans and 2 small cans in front of it. A metal wheel behind each large can will close the row while a slide not disk will open the row before the small cans. Two row markers will operate with the planter up/down rope and a chain will make the row marker alternate. It is not a three point hook up, but has a threaded bolt instead of the regular hitch and pin I am used to. I have many questions about this planter as I would not only want to restore it but use it as well, but I guess my first problem is to ID it asap as the wife want to plant flowers in it, if it is just going to sit around. Just kidding, but I remember my grandfather farming with a Farmmall H and super M and plowing with a 3 bottom plow, picking with a 2 row picker. So what my point is, unlike JD with the 71 flex, I think this planter was used in the field and not a garden. Any help will be greatly appreciated and much needed. I am not sure how to send pitcures here but can sent pictures if anyone needs them.
Steve - IN
08-24-2003 22:03:23
 Re: 2 row corn planter in reply to Gary, 08-24-2003 15:32:23
Gary,
As the other guys have said, odds are nearly 1:1 it's a 290 - in any even your description sounds a heckova lot like my 290.
If you call the number Frank gave you below, you'll want to order OMB25260-J7 which is the English language operators manual for a 290.
If you really use it, you'll need to get a cross reference from the old cast iron plates to the new plastic plates - unless you can find the right cast iron plates at an auction or on Ebay. Maybe the best place for an iron to plastic x-ref is at Fielder's Choice Direct, which you can find on the web.
Lary
08-24-2003 17:27:20
Gary; It's a 290.
F-I-T
08-24-2003 15:50:45
Gary:
I'm not an expert on corn planters, but it sure aounds like a Model 290 to me. We had the four row version known as the 490. Books are still available from Deere. Call them at 800-522-7448.
Frank-in-Tallahassee
70D // 855
