Clooney my 720 flywheel
TRinIA
08-24-2003 14:19:03
Someone has made a plate running horizontal in the gap of the flywheel, held in with one of the two flywheel bolts. It protrudes past the inside of the flywheel about a quarter of an inch, just enough to go in the slot of the brass thrust washer. When I took it apart there was no pin on the flywheel. I bought a new pin to see what it looked like. Mine is a later style seal setup according to the parts book, serial number is 721 7590. I guess my question is, did all flywheels originally have this drive pin. If so mine was broken off and would it matter where I drilled a hole to put the new drive pin in it.
Clooney
08-24-2003 17:20:41
 Re: Clooney my 720 flywheel in reply to TRinIA, 08-24-2003 14:19:03
TRinIA, yes, all the diesel flywheels had that spacer drive pin..
~It doesn't make any difference where you install that pin as long as it will fit in the spacer slot & drive the spacer.....
TRinIA
08-24-2003 18:25:19
 Re: Re: Clooney my 720 flywheel in reply to Clooney , 08-24-2003 17:20:41
Thanks Clooney!!!
