Installing Rear Cam Bushing on 420?
Henry J
08-24-2003 08:54:13
I got my 420 block back from the machine shop and got as far as installing the camshaft. Ther rear cam bushing is not installed properly which results in not allowing enough room for the special plug from JD to be installed in the rear end of the cam bore.
The fun part is that my 420 manual referrs me to Sec 60 Group 30 SM 2013 Model 40 Series tractors for detailed instructions on cam bushing installation. The front one looks like a no brainer since the bushing aligns exactly with the bore when the oil hole is aligned with the block oil passage.
Now comes the rear one, it has a round hole that looks like you would line up with the oil passage. It also has a half moon on the rear end of the bushing. If you like up the hole with the cam bore oil passage, the bushing is not in the block far enough to be centered on the cam bearing surface or to allow the rear plug to be driven in flush with the block.
My question is how this rear bushing is installed and how far in the cam bore is it driven. The little half moon apparently comes into play on the rear bushing.
Thanks in advance for your help.
Clooney
08-24-2003 09:29:10
 Re: Installing Rear Cam Bushing on 420? in reply to Henry J, 08-24-2003 08:54:13
Henry J, Sec 60, Group 30, SM 2013 for the Model 40 won't really help you that much as it gives the installation instructions in reference to positioning with AM 458T cam bushing driver set..... If you don't have that tool it won't help as that tool controls the bushing depth. ~That notch in the rear cam bushing goes to the rear. The oil hole in the bushing MUST be lined up with the oil slot in the block [that's not very hard as the oil slot is pretty wide].
~The rear cam bearing bore plug should be driven in so it's front face is exactly 13-7/32" from the front cam bearing front face. That tells you that that rear bushing rear edge must be forward at least that much for the rear plug to be able to go in that far.
~Not much else to say except those [front & rear] bushings must be kept on the same center line or the bushings will have to be reamed for the cam to fit properly.
Henry J
08-24-2003 10:24:58
 Re: Re: Installing Rear Cam Bushing on 420? in reply to Clooney , 08-24-2003 09:29:10
Clooney
Apparently the oil passage for the rear cam bushing is a slot and that will allow moving the bushing forward to the prescribed depth.
IT is back to the machine shop tomorrow. I appreciate that depth measurement information. He has the drivers and we can recheck the centering when the bushing is at the right depth.
