2550 Power Steering Seal Set Savvy
Wendy
08-24-2003 07:50:54
Please!!! Anything other than: "Ya shoudn't 'ave gone an done that there Li'l Missey!" Actually, I am looking for a few tips, tricks, and possible devices on getting the o-rings and back up rings back inside the shaft housing without damaging them. Thanks.
John
08-24-2003 11:13:14
 Re: 2550 Power Steering Seal Set Savvy in reply to Wendy, 08-24-2003 07:50:54
Ayup, Davidval has it right as usual. I can only add generic advice about o-rings and seals. Generaly their easier to install when you use a lubricant (Hygard) Some respond to a hot water bath to reduce "memory" so they stay in place better. And I`m glad Little Missy wasnt bashful about getting her little hands dirty trying fix her tractor.
davidval
08-24-2003 09:10:15
i assume it's a power steeing. only the 6 upper o rings and shaft seal are replaceable without removing the steering assembly and it's not an easy job, especially with the light colored o rings. it takes practice and patience and a good light source and two long o ring needles.
be very careful when returning the valve assemply into the housing, these o rings tend to tear on assembly.
david
