420 sheetmetal won't fit.
Chris
01-18-2004 07:59:59
I bought this 420 from a JOhn Deere Mechanic (retired). He put on a power steering unit and I have fought with the hood and nose cone for about 2 days strait and still can't get them to line up with each other or the holes in the brackets or the brackets themselves. Anybody else had this problem? I took off the Power steering stuff and went back to the old manual steering column. The parts fit a little closer but still no where near where they are suppposed to. I can't see anywhere where theparts are hitting either. Also what is a good working complete power steering unit worth for a 420W. Thanks for all of the info.
Bus Driver
01-18-2004 17:45:18
 Re: 420 sheetmetal won't fit. in reply to Chris, 01-18-2004 07:59:59
My similar experience is with an M. Get one hole lined up and fasten it. That will help hold the part while you push to get the others aligned. I do the hood one side first also.
Ray
01-18-2004 11:43:47
I'm interested in the PS unit.
Wayne in Tn.
01-18-2004 08:43:00
Chris, sometimes that sheetmetal can be a pain on the 40 and 420 models. If ever in the past the tractor has been rolled over or a tree cut down on the hood, its almost impossible to make it fit correct. If you already have it painted, then you have a big problem. First I would get out the tape measure and a long straight edge of steel and a string. Measure the center of all the mounting holes in the hood, then compare with the mounting brackets on the tractor, you can bend these to line up with the hood. Then use a string and make sure they all are in a straight line. If the hood and nose are warped, you will have to use a body hammer and a smooth surface to pound the metal back straight, then use body filler to finish and paint. If you will notice, on that 420 there are about 10 or so panels or ridges on the hood, to have to be flat or not (wavy)
chris
01-18-2004 11:56:40
 Re: Re: 420 sheetmetal won't fit. in reply to Wayne in Tn., 01-18-2004 08:43:00
Thanks alot for the help. I was up late last nights and was getting frustrated with it so I will go back this afternoon and try your advice. Thanks for the help.
