830 fuel transfer pressure? post the other day
robert
08-24-2003 06:07:18
A post a day or so back,some speak of 67psi feeding injection system.Please explain.Is there an updating kit that replaces the old 12-24psi system??I know when I shimmed ball and spring under transfer pump from say 8 psi to 15 psi the power when plowing went from 2nd gear to pulling 5-14s in 3rd.My service book(JD)just does not speak of these higher pressures a couple of the posters talked about.Thanks.
JDGnut
08-25-2003 15:06:04
 Re: 830 fuel transfer pressure? post the other day in reply to robert, 08-24-2003 06:07:18
Robert.. the specs were from the Injection pump manuals for those pumps.. not the tractor manuals... The pump manual had it broken down by SN# for the tractors..
JDGnut
Gpower
08-24-2003 11:02:50
There is not an update for the transfer pumps, but what happened later on in the 50's the diesel fuel systems were changed so that there is a pressure relief valve installed on the bridge. You will see this as a line coming out of the fuel compartment cover and going back to the fuel tank. The relief valve is right above the pump cover and screws into the bridge. Earlier models were having trouble with gaskets leaking due to high pressures coming from the transfer pump, so this was thier remedy. You could install the relief valve setup on earlier tractors if so desired.
When your tractor has the relief valev system, you were able to bump up the pressure in the transfer pump as you had a "protection" device installed now. You will need to check out the relief valve and make sure the ball and spring in it are in good shape and will allow the pressure to build up to 60 psi. Some are worn so that you cannot obtain the higher psi. You will notice even better power at the higher pressure, not so much that you are gaining HP but you are keeping that fuel system supplied with a good VOLUME of fuel, and you are not starving, like when the rack opens up, and needs more volume of fuel to compensate, it is there at the higher psi and starving it. I hope this make sense, and hope it is the info you are looking for. If you need any other info or specs, just drop me a line. Good Luck,
Gpower
