1020 pto clutch
tim jones
08-23-2003 20:52:34
I have a 1020 john deere ,I was using it today and I noticed that when I pushed down on the clutch to engauge the pto it wouldn't go into gear, I had to force it. You can imagine the grinding sound it made. Can anyone give me an idea of what I should look for? And does the hydraulic fluid in the rear end play any roll in
the pto clutch operation? Thank's
Big Tom
08-27-2003 14:37:35
 Re: 1020 pto clutch in reply to tim jones, 08-23-2003 20:52:34
I had the same symptoms with my 1020 recently, however the problem was with the bolt that is used to adjust the travel to the foot clutch and the pto. It must have loosened and changed the set point of engagement. Eventually it fell off and the tractor could not be stopped except by shutting down the engine. You should have seen the look on my Son's face. Lucky we were on flat land.
Hope this helps.
John
08-24-2003 11:29:44
Nope, your hydraulic oil in the rear end only lubricates the PTO quill. If your tractor is equiped with a "live" PTO ("two stage clutch") then I suspect your PTO clutch has "stuck" to its mating surface. I can only suggest a possible cure shy of splitting you tractor. Remove the 3inch access cap just above the clutch pedal. Strap the pedal ALL the way DOWN with a wire or bungee cord. That accomplished it mite be possible to insert a narrow bar in to the clutch housing access hole and maybe a few sharp raps on the INNER pressure plate may break it loose. I have never had need to do it but its worth a try. Lot quicker than a tractor split. Which isnt that hard a project either.
