Help !
Fred McIntire
08-23-2003 20:37:52
I have what I think may be a real problem. I have a JD 50 with a hand clutch. I tried to start it today after it sat since January or February. I cannot get the clutch to snap forward. I tried rocking it and turning over the engine to no avail. I then loosened up the bolts that attach the clutch lever to the clutch housing. The assembly then slipped out. I thought I got it back correctly; however, when I tighten the bolts down I cannot get the pulley to spin. I think I may have gotten the clutch gears out of alignment, if you can do such a thing. The engine now turns very slowly and seems to bind. I have to bump the starter to get it to turn the engine. How do I check to make sure I have everything lined up correctly?
Also, how can I check to see if there is voltage going into the coil from the ignition switch? Can I run a wire directly from the battery to the coil or will that be too much voltage.
It is a 12 volt system, positive ground.
Can someone please help me? Thank you very much!
Lee
08-25-2003 02:43:28
 Re: Help ! in reply to Fred McIntire, 08-23-2003 20:37:52
I don't know 50s but it sounds like you got one side of the clutch fork stuck in there wrong. Disconnect the clutch linkage and remove those bolts and the fork to reinsert the fork properly? Original problem may be rust on the clutch plate making your 'adjustment' on the clutch too long? If so, then running the engine and applying a load would have sanded the rust out in short order.
Yes you can jumper direct from the battery, it is too much voltage to run at constantly but for a few minutes test it would be fine. Don't leave it hooked up and not running either as the coil will get too hot in the same time frame even if it is not running. A test light would be all you need to show if you got juice at the coil but a voltmeter would show you how much and as such is the better equipment to have and use.
Fred McIntire
08-25-2003 15:48:59
 Re: Re: Help ! in reply to Lee, 08-25-2003 02:43:28
Thanks! You are probably right. I'll try that and let you know how it goes.
Regards,
Fred
