Hydraulic shud-d-d-d-d-er after couple seconds?
scott
08-23-2003 19:20:21
i have a 2130 with loader that shud-d-d-ders when you lift the loader or the rear lift. it seems great for the first few seconds, but then goes to shud-d-d-dering, it still lifts and when you stop and re-start the lift, it does it again. i have changed all the filters and checked the pump, all is well. i imagine it is the pump running out of fluid, perhaps a restriction, but have no idea due to not finding a restriction. what about the accumulator on the side of the block, what is its purpose? are there any other filters other than the one on the side of trans case and the one in the pump valve plate?
all replies, including get lost jerk would kindly be appreciated!
thanks folks,
scott
davidval
08-24-2003 03:35:07
 Re: Hydraulic shud-d-d-d-d-er after couple seconds in reply to scott, 08-23-2003 19:20:21
could be either poor supply to the main pump or a major leak in the hi pressure system.
email if interested in testing.
david
Gman
08-23-2003 19:54:53
Scott my John Deere 4000 lift stuttered as you say I changed all the hydraulic fluid(be sure to put back John Deere Hy-gard) and this cured my problems. Gman
scott
08-23-2003 19:56:48
 Re: Re: Hydraulic shud-d-d-d-d-er after couple sec in reply to Gman, 08-23-2003 19:54:53
should have explained, i changed all fluids and filters i think -- but i do appreciate the input...
scott
Jonathan
08-23-2003 21:47:43
 Re: Re: Re: Hydraulic shud-d-d-d-d-er after couple in reply to scott, 08-23-2003 19:56:48
There should be a suction screen in the transmission ...did you check that ?? When they start to plug up it will make the front pump chatter..
