720D flywheel
TRinIA
08-23-2003 17:20:45
Can anyone tell me how my flywheel should be? When I took it apart it had a about a quarter inch of crankshaft end play and bad oil leak. Someone has made a plate and bolted it on with the flywheel to turn the thrust washer housing. I ordered a new drive pin but I don't see where the old one was broken off of the flywheel. Will it hurt to drill a hole in the flywheel to use the new drive pin? Will it matter where the drive pin goes?
Clooney
08-24-2003 05:34:43
 Re: 720D flywheel in reply to TRinIA, 08-23-2003 17:20:45
TRinIA, your post is a little confusing. ~Are you saying someone bolted a plate between the inside of the flywheel & flywheel spacer? ~If so, did it have a hole to clear the original spacer drive pin? [explain this plate in detail please?]
~As for a new drive pin? It should work but there was [still might be] a reason that plate was installed.
~There is a difference between the early & late 720D's it the flywheels, flywheel spacer, how the crankshaft end play is controlled & if it uses endplay controlling thrust washers. [basically the flywheel through the spacer & housing is different between the early & late tractors].....Just using a serial number to tell the difference won't work as a lot of the early tractors have been updated. ~My first suggestion would be to get a parts manual for your 720D, then identify ALL the flywheel related parts on your tractor so you know what you are working with [there is a good chance you have mixed year parts & that spacer was used to get everything to work & fit together] --I have seen some strange mix & match of parts on those 2-cylinder diesels over the years..... .....
