2010 needs help
Steve
08-23-2003 14:40:00
lost a cyl. or is a partial burn.
checked comp. not great but cyl. not firing complete is more comp than neighbor.
seemed to have fuel filters that needed replace. now am getn way more fuel thought
that may cure but no. changed inj. no
have kit for pump should i try that? Steve
scott
08-23-2003 19:42:01
 Re: 2010 needs help in reply to Steve, 08-23-2003 14:40:00
you did not say if it still runs with more fuel, but regardless, if you want to check your pump, you can pull all the injectors and place bottles over the ends, crank the tractor and measure the amount of fuel in each, if the differential is great on the cylinder in question, change the injector with the cylinder next to it, if it continues, then you know its the pump, if it moved to the other cylinder, then its the injector....
scott
