44 model A magneto
ben
08-22-2003 22:34:13
my magneto was working great then today when i tried to start it i lost the "pop" in my magneto..i can turn the rotor shaft by hand and when i turn the flywheel there is no movement in the magneto.. points dont move at all....is the spring busted?? help me please. its a wico X
Clooney
08-24-2003 05:03:12
 Re: 44 model A magneto in reply to ben, 08-22-2003 22:34:13
Ben, the most likely cause is a broken impulse spring [as you suspected].... A broken mag shaft is also a possibility but those usually break while the engine is running so it would have probably quit running last time you used it.
~Just pull the mag cap off, then look at where the rotor is pointing [so you can put the mag back in the same way], then turn the mag so the impulse cup is facing you, then hold the rotor while you turn the impulse drive cup, if the spring [or shaft] is broken it will be evident.... If the mag impulse spring [& shaft] are good then you will have to inspect the governor for gear or shaft problems....
~Any questions just post back [or E-Mail]
[email protected]
John T
08-23-2003 06:10:53
Mornin Ben, I agree with Lee there below, its time to pull the mag and inspect the coupler assembly and see if when you turn it (CCW facing it in the rear) the other side (under cap) of the rotor shaft turns, and if the spring winds then trips. If not, theres a shaft (maybe broke) or coupler assembly (do dogs come out to engage and wind the spring??) or spring (if it dont wind and trip) problem.
Is the governor shaft (which mag fits into) turning??? It turns the same direction and RPM as the flywheel you know. If its not turning when the flywheel does, there may be a governor or gear (to cam) problem. (Lets hope it turns and its only a mag problem lol) The mag couplers female drive slots fit into that female slot notch in the end of the governor shaft.
Let us know what you find and post back or e mail any more questions and findings.
God Bless
John T Nordhoff in Indiana
Lee
08-22-2003 23:52:16
If you can turn the rotor by hand then the shaft is broke or otherwise not engaged with the governor shaft. Time to pull the mag off and take a look see. Mine was a broken shaft, got a distributor instead, never been happier.
