Generator question???
Ray
08-22-2003 11:10:43
I bought a 420 a few days ago,when it idles
sometimes the generator makes a noise,it comes and goes.The front bearing has some slop so I
figured that was the problem.I took it to a repair
shop,they now tell me the armature is bad and
ordered a new one.It was charging fine when I
took it off,just a noise now and then.Can an
armature be bad and still charge??
tom
08-22-2003 14:04:42
 Re: Generator question??? in reply to Ray, 08-22-2003 11:10:43
Ray,
John T has pretty well spelled it out...I just took my generator to a shop based on a good reference...mine was shot and it cost $95 to replace the armature, primary coils, bushings and bearing, then all the brushes [3 brush gen.]--then they stripped it down, cleaned, polished and painted both the inside and outside, replaced the gasket, replaced the both posts and the post insulators and re-wired the inside...I basically left with a new gen., just the same serial number. These guys were hightly recommended and I do trust them...so, who recommended you to your shop and do they trust them? That's the answer to your question...good luck.
John T
08-22-2003 11:56:14
Good Afternoon there Ray, the short answer to your question is "yes and no". It depends on whats wrong with the armature and how bad it is as to whether or not it could still charge to some extent, for example:
***************ARMATURE PROBLEMS****************
1) If any of its windings (insulation quality) are bad or going bad, they might short to ground (a good or just partial short) and might get worse when things heats up.
2) If the commutator bar segments are bad and not nice n smooth (maybe burned or pitted or rough) and/or the insulators between the segments are not cut down below the copper as they should be, you could get some brush bounce and poor brush current conduction and noise, yet still some charge.
3) If the commutator copper develops a blackended glaze, that can cause both noise and poor brush conduction yet still some charge depending on how bad things are. A simple cleaning and polishing may cure that though.
*********************BEARINGS********************
4) Bearings can be intermittently noisy at times dependign on when they get a temporary shot of lubrication from heat and/or slinging action causes and even those sealed type bearigns can let dirt in or loose some lubrication and/or wear or develop roughness causign them to make noise.
5) The sleeve bushing bearing can often be externally oiled or the armature removed and fresh clean grease installed.
6) If the bearings get too bad, the armature can get too close the the pole magnets and be ruined.
The trouble is without proper equipment it may not be possible to test an armature fully at home, cuz even if it shows no grounds, it might after a good warm up. I know they are expensive and whether or not ones actually needed I cant say, but you might want to just have the bearigns replaced, clean out the generator case, clean and polish the armatures commutator, replace the brushes and see what happens. It looks like the only other choice is to take the shops word and replace the armature while your at it I guess. Rough brushes or commutators or glazing can cause noise, but thats a fairly easy and inexpensive fix.
Let me know what happens.
Good Luck 2 Ya and God Bless
John T Nordhoff in Indiana
ChuckW
08-22-2003 11:17:15
had the same on 530. Sounds like the front bearing or the brushes making noise. If charging sounds like your armature is good.
