1530 will not start when hot
Plant Doctor
08-22-2003 04:53:34
My 1530 diesel will not start when hot. If I let is set until it cools off it will start like a new tractor. Fuel filter is new and the battery easily turns it over. This just seems in reverse to me, generally a diesel starts easy when hot and harder when cold. When the tractor is hot I can kill the battery trying to start it without even getting any indication it even wants to start. Any ideas?
cannonball
08-24-2003 19:12:01
 Re: 1530 will not start when hot in reply to Plant Doctor, 08-22-2003 04:53:34
just a question how much blowby does the engine have...
JB
08-23-2003 19:59:09
Had a friend with a Ford 6xxx diesel that did the same thing. Once you started it for the day, you had to leave it running. Could pull start it.
The final solution was $800 work on the injector pump.
As someone else said check prices of rebuilt vs new and hourly charge to rebuild.
Good luck
JB
jdemaris
08-22-2003 19:38:14
I agree with the other response. I've worked on quite a few Roosa Master distributor injection pumps that would not start hot. Unlike an in-line pump that actually has a separate high pressure fuel pumps for each cylinder in the engine, the CAV and Roosa Master (Stanadyne)rotary pumps have only one pumping device that serves the entire engine, regardless if it's a four cylinder or an eight cylinder engine. So, hypothetically, an in-line pump is working one-fourth as hard as a distributor pump on a four cylinder engine and ought to last four times as long, but that's not always the reality. Your pump distributes the fuel to the individual cylinders by using a rotating rotor within a head. This unit uses extremely close tolerances, and if it gets scored or eroded, can get to the point when it can not generate enought pressure to crack a 3000 p.s.i. injector nozzle when hot. I haven't checked parts prices lately, but I've seen times that a factory new pump could be purchased at less cost than having a pump rebuilt that requires a new head and rotor. Check around. If your pump does have a bad head and rotor find a shop that sells rebuilt pumps at a fixed price rather than a shop that charges on an individual basis. I've known of a few shops that will sometimes sell a pump at little to no profit (because it needed the new head and rotor) because they make it with fixed pricing on the other pumps that did not require major components.
davidval
08-22-2003 11:41:44
sometimes, when the injection pump is worn, there is not enough pressure buildup to open the injectors when the pump is hot due to increased tolerances and reduced fuel density. you can try, when worm, to connect an injector to its line out of the engine and applying the starter. if there is no or little fuel spray out of the injector tip thats probably the problem.
you can try to speed up starter revolution by applying 24 volts to the starter ONLY while it is working and see if it starts.
the solution to such a problem is replacing the pump with a good one or replacing the hydraulic head at a diesel shop.
david
