730D unburned fuel?
Rick
08-21-2003 19:33:17
I have a 730D when runnig it it will spit a thick oily substance out the muffler or it will run down the exhaust pipe, which I am sure it is unburned fuel. I had just bought this tractor, it had a blown head gasket when I got it. I took the head off, had a valve job done, head planed. At the time I had it apart checked the cylinders and pistons, everything checked out ok. The guy I got it from had recently had injector and fuel pump work done at a JD dealer. I also checked the rail setting and it was set at correct setting. I do not work the tractor hard now. It seems with the warmer weather, it does it less than when it did last winter. Is there anything that can be done to correct this problem, other than to work the 'snot' out of it?
Clooney
08-22-2003 06:54:18
 Re: 730D unburned fuel? in reply to Rick, 08-21-2003 19:33:17
Rick, that black soot & oily substance is a mixture of unburned fuel & possibly some oil mixed in with combustion by-products.
~Some 2-cylinder diesels are worse than others at controlling that oily residue. Usually putting the tractor to work will clear it up [at least temporarily]. That oily spitting is usually a sign that the engine has lost some compression and /or the thermostat is missing or malfunctioning. ~Start with a check of the thermostat to be sure it is there & working. If that part is ok do as WjW suggested & verify the compression release is operating properly [if it isn�t working correctly you would be low on power though].
~You said..� At the time I had it apart (I) checked the cylinders and pistons, everything checked out ok��..That could be part [or all] of your problem there,, If you pulled the pistons out & didn�t replace the rings & didn�t get the original rings back in EXACTLY the same orientation as before you could have ring leakage. Unless those cylinders are completely round, the rings are probably worn elliptical to match the cylinder bores. If the rings are worn to the original bore shape & are then disturbed they won�t match the bore when re-installed.
~Make sure you have good clean fuel in it. Old stale gummy fuel will also tend to burn incorrectly & will leave a lot of unburnt residue in the exhaust. ~You might also have injector nozzles that are partially plugged & causing an uneven spray pattern or big droplets to be sprayed. You might want to pull the injectors out, then turn them around to face forward [don�t worry about the bleed tubes], then crank the engine & look at the spry pattern to see if is nice & crisp, no holes in the pattern, & a nice FINE mist. Look for signs of dripping between squirts. CAUTION: don�t EVER place a hand or finger in front of those spraying injectors as they have enough power to inject the fuel right through your skin�.
~I haven�t ever had any problem with an oily diesel exhaust on a good healthy 2-cylinder tractor but have seen that problem on older worn 2-cylinder diesels.
~One last thought�.Make sure the diesel crankcase vent is open & functioning [it vents through the pony & then through the pony air cleaner if a pony start tractor]. You might try adding [building] a vented oil fill cap for a while just to see if that helps the black soot problem. At least that will tell you if you have a main vent problem���.
[email protected]
Tom in TN
09-01-2003 14:04:30
 Re: Re: 730D unburned fuel? in reply to Clooney , 08-22-2003 06:54:18
Exactly how would one "build" a vented cap? I think I'll try this on my 720d as it is slobering a lot on me also.
I get so much GOOD STUFF here! Thanks yall
Rick
08-22-2003 19:00:24
Thanks for your inputs. A few more things that I should have mentioned. This tractor stars very easy, most times on the first revolution, so I do not think I am low on compression. There is very little blow-by, I cleaned the breather, I also check the blow-by at the oil filler. However this tractor does smoke a lot, it will drive you out of a building very fast, more so than my '71 3020. But it also does have very good power.
WjW
08-22-2003 02:43:46
Rick,
Did you check your compression release?
If you are not set right you can get the slobbering you mentioned and since you said the head was recently done this could be a simple ( cheap) explaination. Follow your book's set up and you should be fine. Working the snot out of her won't likely get rid of your problem. when all is well they don't slobber.
MIKE HANLEY
08-21-2003 21:01:18
See the post below on the 830D pump pressure. We are leaning to the fact that just because rack and injector work was done by "PRO's" dosen't make it right. The rack that went to Turddle Lake was done by a diesel shop in La Crosse at the overhall and now it appears it was timed wrong by that shop with the ajustments under the rack..
