830 diesel fuel primary gear pump setting question
robert
08-21-2003 18:29:45
book says set with washers to 12-24psi at high idle.does one achieve a little more power at 24 psi vs 12psi on this set up???
JDGnut
08-22-2003 08:16:43
 Re: 830 diesel fuel primary gear pump setting ques in reply to robert, 08-21-2003 18:29:45
Check the pressure under a load??? See if it is dropping off.. The spec for 80-830 is 18-26 psi up to SN# 8306832.. after that the spec is 57-67 psi.. And all fuel systems that have been changed over.. using the Presure Relief Kit should also be 57-67psi.. We run all our tractors about 65psi... (sometimes a little higher..)
You guys are killing me.. Our dyno shows different results... So have the results on the pulling track...
If she ain't smokin.. she ain't working...
JDGnut
Duane(Pa)
08-22-2003 19:45:04
 Re: Re: 830 diesel fuel primary gear pump setting in reply to JDGnut, 08-22-2003 08:16:43
Is a different spring used with the Pressure Relief System? The spring in mine looks slightly bigger than you'd find in a ball point pen. I don't think any amount of washers would take it to 57 psi. Velly Intellesting
Gpower
08-22-2003 09:29:28
My R is set at 65-75 psi, you can notice a big difference from 5-15 psi and 65-70 psi, you will notice it in the idle and when she goes to a good load. Ive attempted to explain this several times, but Im not to good at getting it across I guess. Ive seen it on the dyno, and on the track. I do not know what you are doing when you are attempting to adjust the pressure in the pump. I know you can raise the pressure in them. You can also get an electric pump and just bypass the transfer pump and adjust the pressure and see the difference for a quick test. Other than that I do not know what else to tell you.
good luck
Mo-Power
WjW
08-22-2003 02:53:39
Robert,
Increasing the pressure on the transfer pump won't do much for power as long as there is enough to keep the rack supplied and anywhere in the books range will work, unless you are trying to get 200hp or something which is different. If you feel underpowered you can increase the rack setting , but you will use more fuel and start smoking pretty good if in excess. If you go too much you may even start to loose power.
MIKE HANLEY
08-21-2003 20:52:41
If you go back several pages, you will see I had the same question on a 730D. Three 730D's and we can't raise the pressure up past 18# on any of them. Added washers while it was on the dino and by addeing washers we dropped the horsepower by 5 horse. Old parts in that one. Another one has all new gears, shaft, seals ans relife valve spring and ball and that one won't go over 18#. All are short on HP on the dino. My buddy Ray sent the rack out to the JD Dealer at Turddle Lake. Last report: the screws on the timeing under the rack was off. Still don't have it back yet. Will report when it comes back and is dino again.
rtobert
08-22-2003 04:32:03
 Re: Re: 830 diesel fuel primary gear pump setting in reply to MIKE HANLEY, 08-21-2003 20:52:41
I thought I set at 12 psi last winter.Now its at 8 psi and I will now re-washer to hopefuly get more psi.Sounds like 8 psi may have starved me a wee bit.
